- The same bug fix that was done on pc386 to prevent interrupt
from occuring (never experienced it but who knows as I have 8259
emulation :()
- Removed every compiler warning (except wrong ones and ones I can't do
anything).
- Removed any libc available code in code linked with mcp750 rtems
executbale. Unfortunately using newlib functions for linking the
bootloader does not work as the compilation options in bootloader
(-mrelocatable -fixed-r13) are not compatible with newlib options.
=> I have put any libc external reference in one single new file (lib.c)
that is linked only with the boot loader. Removing the file from
${OBJ} and using -lc crash the bootloader. Added big warning...
