* network/network.c: Add include of <sys/errno.h>.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* console/console.c, ide/pcmcia_ide.c, network/network.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c:
Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Add irq.h and vectors.h
* wrapup/Makefile.am: Convert to automake-building rules.
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* ide/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* clock/p_clock.c, ide/pcmcia_ide.c, include/bsp.h, include/coverhd.h,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c,
startup/mmutlbtab.c, startup/setvec.c, startup/start.S,
vectors/vectors.h, vectors/vectors_init.c: URL for license changed.
* ide/Makefile.am: Don't include @RTEMS_BSP@.cfg.
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained.
* ide/.cvsignore: Add.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
* startup/linkcmds*: Add FreeBSD sysctl() sections.
