* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
significant things:
and PowerPC
same code base.
