* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c, network/network.c: Removed warnings.
* clock/p_clock.c, console/console.c, startup/bspstart.c: Removed
warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/coverhd.h: Per PR261 removed include of
<rtems/score/targopts.h> because the file is no longer being
generated and really wasn't being used anyway.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
Fix loopCounter.
* irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* startup/bspstart.c: Include <libcpu/cpuIdent.h>, <rtems/bspIo.h>.
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
Remove RTEMS_ENABLE_LIBCDIR.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vector/vector.S, irq/irq_asm.S: Make sure vectors work properly
in RAM and Flash based code. The code executed for the Flash
version runs in both cases (code in Flash/code in RAM) but as it
is less efficient than the one optimized for RAM, it put it inside
ifdef. A compilation error is generated if code is linked in Flash
with the correct ifdef set...
* irq/irq.c: Correct minor bug in mbx8xx interrupt handling.
Quoting Eric, "In theory it should be applied in each mpc8xx
related BSP but as I cannot test it plase maintainer/users
submit patch accordingly."
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* wrapup/Makefile.am: Apply @exceptions@.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* clock/p_clock.c, include/bsp.h, include/coverhd.h,
startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c,
startup/start.S: Fixed typo.
* configure.in: Remove.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* include/bsp.h: Added include of <bsp/vectors.h>
* vectors/vectors.h: Corrected typos.
* network/network.c: Fix unnecessary double assignment.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
* startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h,
libio_.h, libio.h, and libcsupport.h moved from libc to
lib/include/rtems and now must be referenced as <rtems/XXX.h>.
Header file order was cleaned up while doing this.
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* console/console.c: Added BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() required by mbx8xx
console-generic code. This avoids libcpu use of bsp.h.
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET, RTEMS_CANONICAL_TOOLS
* README:
* include/bsp.h:
Add support for configuration parameters in NVRAM
* console/console.c: Fix polled input.
