2010-04-30 | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -4/+0 | |
* include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * include/irq.h: Moved defines from 'include/irq-config.h'. | |||||
2009-10-23 | Update for exception support changes. | Thomas Doerfler | 1 | -3/+11 | |
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed. | |||||
2008-09-26 | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+8 | |
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling. | |||||
2007-01-08 | Regenerate. | Ralf Corsepius | 1 | -3/+3 | |
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+2 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-10 | New. | Ralf Corsepius | 1 | -13/+23 | |
2006-01-10 | New. | Ralf Corsepius | 1 | -28/+31 | |
2005-01-03 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+3 | |
* Makefile.am: Remove build-variant support. | |||||
2004-10-20 | Preinstall tm27.h | Ralf Corsepius | 1 | -0/+4 | |
2004-10-20 | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* include/tm27.h: New. * Makefile.am: Add tm27.h | |||||
2004-02-19 | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+29 | |
* Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* Makefile.am: Reflect changes to bsp.am. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* Makefile.am: Misc cleanups and fixes. | |||||
2003-09-29 | 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -3/+8 | |
* Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
2000-11-02 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | |||||
2000-10-27 | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -2/+2 | |
2000-01-31 | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -7/+1 | |
that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | |||||
1999-12-21 | Patch rtems-rc-19991203-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -3/+0 | |
which ontains all what was left over from the other patches (Primarily minor configuration cleanups). To apply: patch -p1 < rtems-rc-19991203-9.diff ./bootstrap | |||||
1999-12-13 | Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+24 | |
which adds automake support to libbsp/bare. |
