* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 1 | -3/+9 |
| | | | | * console/console.c, network/network.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 1 | -7/+6 |
* | 2001-08-31 Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 2001-08-31 | 1 | -8/+4 |
| | | | | | * network/network.c: Fix to account for return value when installing interrupts handler. | ||||
* | 2001-04-11 Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 2001-04-16 | 1 | -1/+1 |
| | | | | * network/network.c: Fix unnecessary double assignment. | ||||
* | 2001-03-30 Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 2001-04-06 | 1 | -38/+50 |
| | | | | | | | | | | | | | | | * clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, include/8xx_immap.h, include/commproc.h, include/mbx.h, irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c: New files. * Makefile.am, configure.in, console/console.c, include/Makefile.am, network/network.c, startup/Makefile.am, startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds, startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am: The modifications to this BSP reflect the conversion of the mpc8xx CPU to the "new exception processing model." | ||||
* | 2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca> | Joel Sherrill | 2000-08-25 | 1 | -1/+54 |
| | | | | | | | | | * README: * console/console.c: * include/bsp.h: * network/network.c: * startup/bspstart.c: Add support for configuration parameters in NVRAM | ||||
* | 2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca> | Joel Sherrill | 2000-08-10 | 1 | -1/+1 |
| | | | | | | | | | | | * README: Updated. * console/console.c: Addition of support for shared printk and no termios. * include/bsp.h: Addition of second parameter to rtems_enet_driver_attach. Removed prototypes for printk and BSP_output_string. * network/network.c(rtems_enet_driver_attach): Addition of second parameter to function. | ||||
* | Patch from John Cotton <john.cotton@nrc.ca> to correct cache | Joel Sherrill | 2000-06-14 | 1 | -4/+4 |
| | | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching. | ||||
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 1 | -0/+1702 |
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 |
