path: root/c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (follow)
* Obsolete and remove powerpc/mbx8xxJoel Sherrill2016-01-231-347/+0
| | | | closes #2545.
* bsp/mpc8xx: Fix warningsSebastian Huber2014-12-121-5/+5
| | | | close #2211
* bsps: Add shared default IRQ handlerSebastian Huber2012-03-241-5/+0
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-111-2/+2
| | | | | * console/console.c, irq/irq.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-01-281-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c, ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c, gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c, haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h, motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c, mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h, mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h, psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h, psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c, psim/startup/linkcmds, psim/tools/psim-gdb-top.in, psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h, score603e/irq/irq.c, shared/bootloader/bootldr.h, shared/bootloader/em86.c, shared/bootloader/em86real.S, shared/bootloader/exception.S, shared/bootloader/head.S, shared/bootloader/lib.c, shared/bootloader/misc.c, shared/bootloader/mm.c, shared/bootloader/pci.c, shared/console/console.c, shared/console/consoleIo.h, shared/console/inch.c, shared/console/keyboard.h, shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h, shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c, shared/motorola/motorola.h, shared/openpic/openpic.c, shared/openpic/openpic.h, shared/pci/pci.c, shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h: Fix typo where license said found in found in.
* Whitespace removal.Ralf Corsepius2009-11-301-4/+4
* Update for exception support changes.Thomas Doerfler2009-10-231-278/+107
* Convert to "bool".Ralf Corsepius2008-09-061-1/+1
* Add missing prototypes.Ralf Corsepius2008-08-201-1/+1
* adapted gen83xx to new boardThomas Doerfler2008-05-151-0/+12
* 2007-12-08 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-12-081-2/+3
| | | | | | | | | | * ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c, mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h, shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c: let C_dispatch_irq_handler() return zero to indicate to low-level exception handling code that the exception was handled (not used yet).
* 2007-11-06 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-11-061-8/+16
| | | | | | | | | * ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c, score603e/irq/irq.c, shared/irq/irq.c: test for non-NULL-ness before calling 'on'/'off' methods so that users don't have to provide no-ops if they don't want this feature.
* 2007-09-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-09-121-13/+14
| | | | | | | | | | | PR 1257/bsps * irq/irq.c: Code outside of cpukit should use the public API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the public API and directly accessing _CPU_ISR_Disable and _CPU_ISR_Enable, they were bypassing the compiler memory barrier directive which could lead to problems. This patch also changes the type of the variable passed into these routines and addresses minor style issues.
* 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-171-9/+9
| | | | * irq/irq.c, irq/irq.h, network/network.c: Modified to use rtems/irq.h.
* 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-041-1/+1
| | | | | * clock/p_clock.c, irq/irq.c, irq/irq_init.c: Addition of a parameter to ISRs
* 2005-04-15 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-04-151-1/+1
| | | | | | PR 779/bsp * irq/irq.c, irq/irq.h: add parameter to new exception interrupt handlers in powerpc bsps
* Remove duplicate white lines.Ralf Corsepius2004-04-211-4/+0
* Remove stray white spaces.Ralf Corsepius2004-04-211-25/+25
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | * clock/p_clock.c, ide/pcmcia_ide.c, include/bsp.h, include/coverhd.h, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c, startup/mmutlbtab.c, startup/setvec.c, startup/start.S, vectors/vectors.h, vectors/vectors_init.c: URL for license changed.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-2/+3
| | | | | | | | * irq/irq.c: Reflect changes to <rtems/score/cpu.h>. Fix loopCounter. * irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>. * vectors/vectors.S: Ditto. * vectors/vectors_init.c: Include <rtems/bspIo.h>.
* 2001-01-16 Eric Valette <valette@crt.canon.fr>Joel Sherrill2002-01-161-1/+1
| | | | | | | * irq/irq.c: Correct minor bug in mbx8xx interrupt handling. Quoting Eric, "In theory it should be applied in each mpc8xx related BSP but as I cannot test it plase maintainer/users submit patch accordingly."
* 2001-03-30 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-061-0/+506
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, include/8xx_immap.h, include/commproc.h, include/mbx.h, irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c: New files. * Makefile.am, configure.in, console/console.c, include/Makefile.am, network/network.c, startup/Makefile.am, startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds, startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am: The modifications to this BSP reflect the conversion of the mpc8xx CPU to the "new exception processing model."
