* console/console.c, ide/pcmcia_ide.c, startup/bspstart.c,
startup/imbx8xx.c: Fix some warnings.
* ide/pcmcia_ide.c: Updated to the libblock changes.
PR 703/filesystem
* ide/pcmcia_ide.c: Extend the "modes_available" and "mode_active" parameters
to uint16_t for UDMA support.
* console/console.c, ide/pcmcia_ide.c, network/network.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c:
Convert to using c99 fixed size types.
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
* clock/p_clock.c, ide/pcmcia_ide.c, include/bsp.h, include/coverhd.h,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c,
startup/mmutlbtab.c, startup/setvec.c, startup/start.S,
vectors/vectors.h, vectors/vectors_init.c: URL for license changed.
* ide/Makefile.am: Don't include @RTEMS_BSP@.cfg.
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
* ide/.cvsignore: Add.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
