* console/console.c, ide/pcmcia_ide.c, network/network.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c:
Convert to using c99 fixed size types.
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c, network/network.c: Removed warnings.
* clock/p_clock.c, console/console.c, startup/bspstart.c: Removed
warnings.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* console/console.c: Added BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() required by mbx8xx
console-generic code. This avoids libcpu use of bsp.h.
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
* README:
* include/bsp.h:
* network/network.c:
* startup/bspstart.c:
Add support for configuration parameters in NVRAM
* console/console.c: Fix polled input.
* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
significant things:
and PowerPC
same code base.
