* configure.ac, startup/bspstart.c, include/coverhd.h: Use standard
cache BSP options.
* console/console.c, irq/irq.c:
* console/console.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* console/console.c, ide/pcmcia_ide.c, startup/bspstart.c,
startup/imbx8xx.c: Fix some warnings.
* irq/irq.h: Add BSP_irq_enabled_at_cpm.
* network/network.c: Remove local decl of BSP_irq_enabled_at_cpm.
* make/custom/mbx8xx.inc: Remove RTEMS_BSP_FAMILY.
* make/custom/mbx8xx.inc: New (Renamed from mbx8xx.cfg).
* make/custom/mbx8xx.cfg: Removed.
* make/custom/mbx821_001.cfg, make/custom/mbx821_002b.cfg,
make/custom/mbx821_002.cfg, make/custom/mbx860_001b.cfg,
make/custom/mbx860_002.cfg, make/custom/mbx860_005b.cfg,
make/custom/mbx860_1b.cfg:
Include make/custom/mbx8xx.inc.
* make/custom/mbx821_001.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002b.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_001b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_005b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_1b.cfg: New (relocated from /make/custom).
* make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/linkcmds: Correct name of ENTRY.
* startup/start.S: Update for boot_card command line change.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* startup/bspstart.c, startup/bspstart.c.nocache: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Create bsp_get_work_area() into its own file and use BSP Framework to
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* ide/pcmcia_ide.c, irq/irq.c, startup/bspstart.c,
startup/bspstart.c.nocache: Convert to "bool".
* clock/p_clock.c, console/console.c, irq/irq.c, irq/irq_init.c,
vectors/vectors_init.c: Add missing prototypes.
* ide/pcmcia_ide.c: Updated to the libblock changes.
* startup/bspstart.c, startup/bspstart.c.nocache: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c, startup/bspstart.c.nocache: Refactored and
renamed initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/bspstart.c, startup/bspstart.c.nocache: Remove all references
to console_reserve_resources and termios_reserve_resources.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c, startup/bspstart.c.nocache:
Eliminate copies of the Configuration Table. Use the RTEMS provided
accessor macros to obtain configuration fields.
* startup/bspstart.c, startup/bspstart.c.nocache: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* Makefile.am: Add bsppredriverhook.c.
* irq/irq.h: Attempt to correct definition of
BSP_CPM_IRQ_LOWEST_OFFSET.
* startup/bspstart.c, startup/bspstart.c.nocache: Moved most of the
remaining CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
