2008-02-19 | Remove (Abandoned). | Ralf Corsepius | 20 | -2587/+0 | |
2007-12-11 | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 4 | -30/+25 | |
* README, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | |||||
2007-12-04 | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 3 | -18/+7 | |
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | |||||
2007-12-03 | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -3/+9 | |
* startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | |||||
2007-12-01 | 2007-11-30 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2 | -2/+4 | |
* startup/bspstart.c: removed bsp_exceptions_in_RAM | |||||
2007-11-28 | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -0/+6 | |
* startup/bspstart.c: Now compiles and links. | |||||
2007-11-28 | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -10/+29 | |
* startup/bspstart.c: Eliminate PowerPC specific elements from the CPU Table. They have been replaced with variables named bsp_XXX as needed. | |||||
2007-04-12 | changes | Ralf Corsepius | 2 | -1/+2 | |
2007-04-12 | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -4/+6 | |
* bsp_specs: Remove qrtems_debug. | |||||
2007-04-06 | 2007-04-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -8/+4 | |
* bsp_specs: Remove lib (Now expected to exist in GCC). | |||||
2007-04-02 | 2007-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* Makefile.am: Add dummy printk support so all tests link. | |||||
2007-01-08 | Regenerate. | Ralf Corsepius | 1 | -2/+2 | |
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-11-15 | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-08-23 | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -10/+5 | |
* startup/bspstart.c: Revert patch adding new exception support code to an old exception BSP. | |||||
2006-08-22 | 2006-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+14 | |
* startup/bspstart.c: Add basic _BSP_Fatal_error. | |||||
2006-08-09 | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+47 | |
* startup/linkcmds: Clean up a bit after adding missing .rela sections. | |||||
2006-03-17 | Remove eof include file | Ralf Corsepius | 2 | -2/+0 | |
2006-03-08 | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+8 | |
* startup/linkcmds, startup/linkcmds.dl: Add .gnu.linkonce.b.* section. | |||||
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -6/+11 | |
* startup/linkcmds, startup/linkcmds.dl: Add sections required by newer gcc versions. | |||||
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+2 | |
2006-01-12 | Remove all-local:. | Ralf Corsepius | 1 | -2/+0 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Cleanup. | Ralf Corsepius | 1 | -3/+0 | |
2006-01-11 | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -4/+5 | |
* configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | |||||
2006-01-10 | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -46/+11 | |
* configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | |||||
2006-01-10 | New. | Ralf Corsepius | 1 | -0/+55 | |
2006-01-09 | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+4 | |
* Makefile.am: Don't include subdirs.am. | |||||
2005-05-26 | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* include/bsp.h: New header guard. | |||||
2005-02-16 | 2005-02-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS. | |||||
2005-02-15 | 2005-02-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* flashentry/flashentry.S: #include <rtems/powerpc/powerpc.h> | |||||
2005-02-12 | Remove. | Ralf Corsepius | 1 | -2/+0 | |
2005-02-12 | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 4 | -26/+19 | |
* Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2005-02-10 | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -8/+5 | |
* dlentry/dlentry.S, flashentry/flashentry.S: Remove PPC_ABI_POWEROPEN. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -3/+7 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-03 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -51/+20 | |
* Makefile.am, wrapup/Makefile.am: Remove build-variant support. | |||||
2004-11-02 | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -3/+9 | |
PR 697/bsps * flashentry/flashentry.S: Fix broken comments (Patch by Thomas.Doerfler@imd-systems.de) | |||||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-23 | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -3/+14 | |
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
2004-04-23 | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -14/+37 | |
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -10/+5 | |
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
2004-04-21 | Remove duplicate white lines. | Ralf Corsepius | 4 | -7/+0 | |
2004-04-21 | Remove stray white spaces. | Ralf Corsepius | 4 | -88/+88 | |
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 2 | -3/+0 | |
2004-04-13 | 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+7 | |
* flashentry/flashentry.S: Include <rtems/score/powerpc.h> instead of <rtems/score/ppc.h>. | |||||
2004-04-02 | * dlentry/dlentry.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 3 | -2/+7 | |
* flashentry/flashentry.S: Include <rtems/asm.h> instead of <asm.h>. |
