* Makefile.am: Merge-in dlentry/Makefile.am, flashentry/Makefile.am,
startup/Makefile.am. Use automake compilation rules.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations for gcc-3.3.x.
Don't preinstall bsp_specs.dl.
* dlentry/Makefile.am: Cosmetics.
* flashentry/Makefile.am: Cosmetics.
Reflect changes to bsp.am.
dlentry/Makefile.am: Reflect having moved automake.
flashentry/Makefile.am: Reflect having moved automake.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* flashentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Remove . from SUBDIRS, add @exceptions@ to
SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
converted to automake.
