* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations for gcc-3.3.x.
Don't preinstall bsp_specs.dl.
* dlentry/Makefile.am: Cosmetics.
* flashentry/Makefile.am: Cosmetics.
* dlentry/Makefile.am: Remove all-local: $(ARCH).
* flashentry/Makefile.am: Remove all-local: $(ARCH).
Reflect changes to bsp.am.
* include/bsp.h, include/coverhd.h, startup/bspclean.c,
startup/setvec.c: URL for license changed.
* startup/bspstart.c: Removed incorrect statement about copyright
assignment.
dlentry/Makefile.am: Reflect having moved automake.
flashentry/Makefile.am: Reflect having moved automake.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* flashentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* flashentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: Fixed typo and added gnu.linkonce.t and
gnu.linkonce.r sections.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds, startup/linkcmds.dl : Per PR170, PR171, and PR172
add .eh_frame.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* flashentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* Makefile.am: Remove . from SUBDIRS, add @exceptions@ to
SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
process was captured as PR50.
* include/bsp.h: Increase the interrupt stack size to 16K.
* startup/linkcmds: Added _init and _fini.
* configure.in: Remove.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
