Use bspreset_loop.c instead. This avoids infinite recursion.
for details.
* Makefile.am: Remove references to non-existing files.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c: Create
bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* Makefile.am: Do not build .rel files. Reduces code bloat.
* Makefile.am: Remove reference to startup/setvec.c.
updated haleakala BSP
added MPC55xx BSP
