not updated.
* make/custom/mpc8309som.cfg, startup/linkcmds.mpc8309som: New file.
* Makefile.am, preinstall.am: Reflect changes above.
* configure.ac, console/console-config.c, include/bsp.h,
include/hwreg_vals.h, include/irq.h, network/network.c,
spi/spi_init.c, startup/cpuinit.c: Renamed various BSP options.
* make/custom/gen83xx.inc, make/custom/hsc_cm01.cfg,
make/custom/mpc8313erdb.cfg, make/custom/mpc8349eamds.cfg: Avoid
special linkcmds.
* include/u-boot.h: Removed file.
* include/u-boot-config.h, include/tsec-config.h: New files.
* include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot
support.
* network/network.c: Update for API changes.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* preinstall.am: Regenerated.
* Makefile.am, preinstall.am: Add dummy linkcmds so autoconf tests work
on installed BSP.
* startup/linkcmds: New file.
updated haleakala BSP
added MPC55xx BSP
* Makefile.am, preinstall.am: Install a linkcmds all the time.
* startup/bspstart.c, startup/cpuinit.c,
startup/linkcmds.mpc8349eamds, startup/mpc83xx_regs.c: Add missing $Id$.
many different versions of new exception handling code to shared sources.
