line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* make/custom/mpc8309som.cfg, startup/linkcmds.mpc8309som: New file.
* Makefile.am, preinstall.am: Reflect changes above.
* configure.ac, console/console-config.c, include/bsp.h,
include/hwreg_vals.h, include/irq.h, network/network.c,
spi/spi_init.c, startup/cpuinit.c: Renamed various BSP options.
* make/custom/gen83xx.inc, make/custom/hsc_cm01.cfg,
make/custom/mpc8313erdb.cfg, make/custom/mpc8349eamds.cfg: Avoid
special linkcmds.
* configure.ac, console/console-config.c, i2c/i2c_init.c,
include/bsp.h, include/hwreg_vals.h, include/irq.h, include/tm27.h,
include/tsec-config.h, irq/irq.c, network/network.c, spi/spi_init.c,
startup/bspstart.c: Address some of the issues spotted by the
check_bsp script.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
updated haleakala BSP
added MPC55xx BSP
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
many different versions of new exception handling code to shared sources.
