* Makefile.am, include/bsp.h, start/start.S, startup/bspstart.c,
startup/cpuinit.c: Use top level shared bsp_get_work_area()
implementation. Augment it to know about U-Boot.
* startup/bspgetworkarea.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
* startup/bspgetworkarea.c, startup/linkcmds.base: Do some prep work in
anticipation of gen5200 and gen83xx being able to shared
bsp_get_work_area() implementation.
* Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in
its own file and rely on BSP Framework to perform more
initialization. Remove unnecessary includes of rtems/libio.h and
rtems/libcsupport.h.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* console/console.h: Convert to "bool".
* console/console.c: Convert to "bool".
* Makefile.am: Added bspclean.c and use shared bsppretaskinghook.c.
* console/console.c: Added poll for char helper.
* include/bsp.h: Add macro definitions for optional reset behavior.
* startup/bspstart.c: Split out bsp_cleanup(). Clean up.
* startup/bspclean.c: New file. Not can press any key on normal
shutdown to reset board when on MPC8313erdb.
* startup/cpuinit.h: Uses now powerpc-utility.h. Changed invalid usage
of a boolean type to a proper integer type in calc_dbat_regvals().
Througout code formatting.
* include/tm27.h: Uses now a decrementer exception handler. Replaces
previous file.
* startup/bspstart.c: Install a default decrementer exception handler.
* include/bsp.h, network/network.c, spi/spi_init.c, startup/cpuinit.c,
startup/uboot_support.c: Fixed warnings.
* Makefile.am, startup/bspstart.c, startup/cpuinit.c: For the
MPC8313ERDB -- The BAT entry for the eLBC was missing and add
hard reset sequence in bsp_cleanup().
* README.mpc8313erdb: Some first cut notes on running with U-Boot.
* startup/bspstart.c: Time was running too slow with it taking 10
seconds for RTEMS to advance 5.
* Makefile.am, preinstall.am: Add dummy linkcmds so autoconf tests work
on installed BSP.
* startup/linkcmds: New file.
* startup/bspstart.c: Fixed calculation of bsp_click_per_usec.
* start/start.S: Clear environment pointer for bootcard. Fixed wrong
address increment in mpc83xx_zero_4().
* Makefile.am: Add stub for U-Boot support. Hopefully someone more
knowledgeable than I can provide a real address and length.
* startup/uboot_support.c: New file.
added support for an optional separate heap area.
fixed some minors in mpc83xx support
added file for mpc55xx watchdog support
initialize PHY registers late enough, so that phy access is possible
* configure.ac: Remove RTEMS_AMPOLISH3.
updated haleakala BSP
added MPC55xx BSP
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds, startup/linkcmds.hsc_cm01,
startup/linkcmds.mpc8349eamds: Add wildcard to gcc_except_table
section so programs compiled with gcc 4.3.x can link.
* Makefile.am: Remove duplicate cases of mmu.rel and timer.rel in list
of objects.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* irq/ipic.c, irq/irq_init.c:
Converted exception vector names to new ones
(qualified by <cpu_type> if non-std ppc exceptions).
* startup/bspstart.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/bspstart: removed _Cpu_table.exceptions_in_RAM.
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* startup/bspstart.c: Eliminate PowerPC specific elements from the CPU
Table. They have been replaced with variables named bsp_XXX as
needed.
added IRQ support to MPC83xx i2c driver
added mpc83xx spi driver
* console/console.c, irq/irq_init.c: Eliminate warnings.
* console/console.c: Eliminate DEBUG_puts.
PR 1257/bsps
* irq/irq_init.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
