Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
* Makefile.am: Added custom memcpy(). Update for network sources.
* configure.ac: Enable interrupt driven Termios for all BSPs.
* ide/pcmcia_ide.c: Disable broken DMA support.
* include/bsp.h: Fixed NEED_LOW_LEVEL_INIT define. Set default
console baud to 115200.
* include/irq.h, irq/irq.c: Fixed interrupt handling to avoid the
following problems: 1. multiple invokation of peripheral interrupt
handlers, 2. missing synchronization after mask write and enabling of
external exceptions, and 3. logic overhead.
* network_5200/network.c: Added MII interface. Fixed controller
restart after FIFO errors. Performance improvements.
* start/start.S: Fixed ROM startup. Initialize XLB arbiter for all
BSPs.
* startup/bspstart.c: Special intialization for MPC5200B (B variant).
Install standard alignment handler.
* startup/cpuinit.c, startup/linkcmds.brs5l, startup/linkcmds.dp2,
startup/linkcmds.icecube, startup/linkcmds.pm520_cr825,
startup/linkcmds.pm520_ze30: Avoid accesses outside the RAM area.
* make/custom/dp2.cfg, startup/linkcmds.dp2: New files.
* Makefile.am, preinstall.am: Reflect change above. Install
<bsp/utility.h>. Install BestComm header files.
* configure.ac: Changed BSP options.
* include/mpc5200.h: Added module structures and register defines.
* bestcomm/bestcomm_api.c, bestcomm/bestcomm_api.h,
bestcomm/bestcomm_glue.c, bestcomm/bestcomm_glue.h,
bestcomm/bestcomm_priv.h, bestcomm/load_task.c,
bestcomm/tasksetup_bdtable.c, bestcomm/task_api/bestcomm_cntrl.h: C++
compatibility. Use special heap to manage the SRAM region. Use
interrupt extension API. Fixed warnings.
* console/console.c: Fixed console registration. Fixed warnings.
Added GPS module registration.
* ide/pcmcia_ide.h: Fixed clock value macros.
* ide/pcmcia_ide.c: Update for BestComm API changes.
DP2 specific initialization. Removed zero loop in PIO receive
function.
* include/bsp.h: Added DP2 variant. Removed obsolete defines.
* include/mscan-base.h, mscan/mscan-base.c: Use volatile qualifier.
Format.
* irq/irq.c: Fixed peripheral interrupt handling.
* network_5200/network.c: Update for BestComm API changes.
* start/start.S: U-Boot fixes.
* startup/cpuinit.c: Enable write-back cache strategy. Added special
memory regions.
* startup/linkcmds.brs5l: Fixed memory size.
* Makefile.am, include/bsp.h, network_5200/network.c, start/start.S,
startup/bspstart.c, startup/cpuinit.c: Use top level shared
bsp_get_work_area() implementation. Augment it to know about U-Boot.
* startup/bspgetworkarea.c: Removed.
* network_5200/network.c: Remove use of boolean.
exception and interrupt code.
* network_5200/network.c: Add multicast support.
* console/console.c: Fix typo accidentally introduced.
* network_5200/network.c: Fix warning.
* clock/clock.c, network_5200/network.c: Convert to using clock driver
template.
* include/mpc5200.h, network_5200/network.c: Convert C++ style comments
to C style.
submission).
