* Makefile.am: Added custom memcpy(). Update for network sources.
* configure.ac: Enable interrupt driven Termios for all BSPs.
* ide/pcmcia_ide.c: Disable broken DMA support.
* include/bsp.h: Fixed NEED_LOW_LEVEL_INIT define. Set default
console baud to 115200.
* include/irq.h, irq/irq.c: Fixed interrupt handling to avoid the
following problems: 1. multiple invokation of peripheral interrupt
handlers, 2. missing synchronization after mask write and enabling of
external exceptions, and 3. logic overhead.
* network_5200/network.c: Added MII interface. Fixed controller
restart after FIFO errors. Performance improvements.
* start/start.S: Fixed ROM startup. Initialize XLB arbiter for all
BSPs.
* startup/bspstart.c: Special intialization for MPC5200B (B variant).
Install standard alignment handler.
* startup/cpuinit.c, startup/linkcmds.brs5l, startup/linkcmds.dp2,
startup/linkcmds.icecube, startup/linkcmds.pm520_cr825,
startup/linkcmds.pm520_ze30: Avoid accesses outside the RAM area.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* make/custom/dp2.cfg, startup/linkcmds.dp2: New files.
* Makefile.am, preinstall.am: Reflect change above. Install
<bsp/utility.h>. Install BestComm header files.
* configure.ac: Changed BSP options.
* include/mpc5200.h: Added module structures and register defines.
* bestcomm/bestcomm_api.c, bestcomm/bestcomm_api.h,
bestcomm/bestcomm_glue.c, bestcomm/bestcomm_glue.h,
bestcomm/bestcomm_priv.h, bestcomm/load_task.c,
bestcomm/tasksetup_bdtable.c, bestcomm/task_api/bestcomm_cntrl.h: C++
compatibility. Use special heap to manage the SRAM region. Use
interrupt extension API. Fixed warnings.
* console/console.c: Fixed console registration. Fixed warnings.
Added GPS module registration.
* ide/pcmcia_ide.h: Fixed clock value macros.
* ide/pcmcia_ide.c: Update for BestComm API changes.
DP2 specific initialization. Removed zero loop in PIO receive
function.
* include/bsp.h: Added DP2 variant. Removed obsolete defines.
* include/mscan-base.h, mscan/mscan-base.c: Use volatile qualifier.
Format.
* irq/irq.c: Fixed peripheral interrupt handling.
* network_5200/network.c: Update for BestComm API changes.
* start/start.S: U-Boot fixes.
* startup/cpuinit.c: Enable write-back cache strategy. Added special
memory regions.
* startup/linkcmds.brs5l: Fixed memory size.
exception and interrupt code.
* irq/irq.c: Add units.
* include/bsp.h, irq/irq.c, irq/irq_init.c, startup/bspclean.c,
startup/bspstart.c: Slightly better names for IRQ benchmarking. Make
sure the routines are present all the time.
* configure.ac, irq/irq.c, startup/bspclean.c, startup/bspstart.c: Add
ALLOW_IRQ_NESTING option. The MPC5200 has a settle time after
acknowledging the IRQs and currently the BSP does not account for
that. After acknowledging an interrupt, it currently gets a second
spurious IRQ a significant percentage of the time. Rename to
BENCHMARK_IRQ_PROCESSING and get it working again. Under one test
load, not nesting interrupts resulted in a 50% reduction in the
number of IRQs and an ~30% reduction in time spent in IRQs.
* irq/irq.c, startup/bspclean.c, startup/bspstart.c: I give. The code
is now in conditionally so I can avoid putting it in accidently
again.
* acinclude.m4, gen5200/irq/irq.c, gen5200/startup/bspclean.c: Add
mvme3100.
* irq/irq.c: Revert accidentally committed test code.
* bsp_specs, clock/clock.c, include/bsp.h, irq/irq.c,
startup/bspclean.c, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* irq/irq_init.c, irq_asm.S:
Converted exception vector names to new ones
(qualified by <cpu_type> if non-std ppc exceptions).
* irq/irq.c: Spacing.
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c,
mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c,
score603e/irq/irq.c, shared/irq/irq.c:
test for non-NULL-ness before calling 'on'/'off'
methods so that users don't have to provide
no-ops if they don't want this feature.
* irq/irq.h: Fixed typos.
PR 1257/bsps
* irq/irq.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* irq/irq.h: Reformat -- make things line up.
* clock/clock.c, console/console.c, ide/pcmcia_ide.c, irq/irq.c,
irq/irq.h, irq/irq_asm.S, irq/irq_init.c, nvram/nvram.c,
nvram/nvram.h, slicetimer/slicetimer.c, startup/bspstart.c,
vectors/vectors.h, vectors/vectors_init.c: Correct license URL and/or
fix mistake in copyright notice. Both of these mistakes appear to be
from code submitted after these changes were made previously.
submission).
