* make/custom/dp2.cfg, startup/linkcmds.dp2: New files.
* Makefile.am, preinstall.am: Reflect change above. Install
<bsp/utility.h>. Install BestComm header files.
* configure.ac: Changed BSP options.
* include/mpc5200.h: Added module structures and register defines.
* bestcomm/bestcomm_api.c, bestcomm/bestcomm_api.h,
bestcomm/bestcomm_glue.c, bestcomm/bestcomm_glue.h,
bestcomm/bestcomm_priv.h, bestcomm/load_task.c,
bestcomm/tasksetup_bdtable.c, bestcomm/task_api/bestcomm_cntrl.h: C++
compatibility. Use special heap to manage the SRAM region. Use
interrupt extension API. Fixed warnings.
* console/console.c: Fixed console registration. Fixed warnings.
Added GPS module registration.
* ide/pcmcia_ide.h: Fixed clock value macros.
* ide/pcmcia_ide.c: Update for BestComm API changes.
DP2 specific initialization. Removed zero loop in PIO receive
function.
* include/bsp.h: Added DP2 variant. Removed obsolete defines.
* include/mscan-base.h, mscan/mscan-base.c: Use volatile qualifier.
Format.
* irq/irq.c: Fixed peripheral interrupt handling.
* network_5200/network.c: Update for BestComm API changes.
* start/start.S: U-Boot fixes.
* startup/cpuinit.c: Enable write-back cache strategy. Added special
memory regions.
* startup/linkcmds.brs5l: Fixed memory size.
