* Makefile.am: Reflect changes to bsp.am.
* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
automake compilation rules.
* dlentry/Makefile.am, startup/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* dlentry/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
* startup/linkcmds.dl: Remove SEARCH_DIR.
* startup/linkcmds: Preparations to gcc-3.3.x.
* dlentry/Makefile.am: Cosmetics.
* dlentry/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
* include/bsp.h, include/coverhd.h, startup/bspclean.c,
startup/setvec.c: URL for license changed.
* startup/bspstart.c: Removed incorrect statement about copyright
assignment.
dlentry/Makefile.am: Reflect having moved automake.
PR 378/bsps
* bsp_specs: Did not include ecrtn in endfile sections. Reported
and fixed by elkolli@crf.canon.fr.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/dlentry.S: Removed fake __eabi to avoid conflict with
the real one provided by gcc. I don't know if this makes this
BSP work for C++ but it at least lets simple programs link again.
* startup/linkcmds: Fixed typo.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds, startup/linkcmds.dl : Per PR170, PR171, and PR172
add .eh_frame.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
