* startup/linkcmds: Preparations to gcc-3.3.x.
* dlentry/Makefile.am: Cosmetics.
* dlentry/Makefile.am: Remove all-local: $(ARCH).
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* include/bsp.h, include/coverhd.h, startup/bspclean.c,
startup/setvec.c: URL for license changed.
* startup/bspstart.c: Removed incorrect statement about copyright
assignment.
dlentry/Makefile.am: Reflect having moved automake.
PR 378/bsps
* bsp_specs: Did not include ecrtn in endfile sections. Reported
and fixed by elkolli@crf.canon.fr.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/dlentry.S: Removed fake __eabi to avoid conflict with
the real one provided by gcc. I don't know if this makes this
BSP work for C++ but it at least lets simple programs link again.
* startup/linkcmds: Fixed typo.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds, startup/linkcmds.dl : Per PR170, PR171, and PR172
add .eh_frame.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs
rules, add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52.
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* include/bspopts.h.in: Automatically generated file that should not
be in CVS.
* startup/linkcmds: Fixed syntax error in my previous addition
of __init.
* startup/linkcmds: Added _init, and _fini symbols.
* .cvsignore: New file.
process was captured as PR50.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
