* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
automake compilation rules.
* dlentry/Makefile.am, startup/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* wrapup/Makefile.am: Reflect changes to libcpu.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Preparations to gcc-3.3.x.
* dlentry/Makefile.am: Cosmetics.
* dlentry/Makefile.am: Remove all-local: $(ARCH).
dlentry/Makefile.am: Reflect having moved automake.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs
rules, add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52.
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
process was captured as PR50.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
<corsepiu@faw.uni-ulm.de> so these BSPs pick up the
components they need from libcpu.
converted to automake.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
that converts the libbsp/i386 subdirectory to full automake.
