* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
automake compilation rules.
* dlentry/Makefile.am, startup/Makefile.am: Remove.
* dlentry/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Cosmetics.
* dlentry/Makefile.am: Remove all-local: $(ARCH).
dlentry/Makefile.am: Reflect having moved automake.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
process was captured as PR50.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
converted to automake.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
