2008-02-19 | Remove (Abandoned). | Ralf Corsepius | 1 | -447/+0 | |
2007-12-11 | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* README, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | |||||
2007-12-04 | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | |||||
2007-12-03 | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+9 | |
* startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | |||||
2007-12-01 | 2007-11-30 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -0/+4 | |
* startup/bspstart.c: removed bsp_exceptions_in_RAM | |||||
2007-11-28 | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* startup/bspstart.c: Eliminate PowerPC specific elements from the CPU Table. They have been replaced with variables named bsp_XXX as needed. | |||||
2007-04-12 | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* bsp_specs: Remove qrtems_debug. | |||||
2007-04-02 | 2007-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Add dummy printk support so all tests link. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-11-15 | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-08-23 | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* startup/bspstart.c: Revert patch adding new exception support code to an old exception BSP. | |||||
2006-08-22 | 2006-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* startup/bspstart.c: Add basic _BSP_Fatal_error. | |||||
2006-08-09 | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* startup/linkcmds: Clean up a bit after adding missing .rela sections. | |||||
2006-03-08 | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* startup/linkcmds, startup/linkcmds.dl: Add .gnu.linkonce.b.* section. | |||||
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* startup/linkcmds.dl: Add sections required by newer gcc versions. | |||||
2006-02-07 | 2006-02-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* startup/linkcmds: Add sections to fix C++ linking errors. | |||||
2006-01-11 | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | |||||
2006-01-10 | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | |||||
2006-01-09 | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Don't include subdirs.am. | |||||
2005-05-26 | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* include/bsp.h: New header guard. | |||||
2005-02-16 | 2005-02-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS. | |||||
2005-02-12 | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2005-02-10 | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* dlentry/dlentry.S: Remove PPC_ABI_POWEROPEN. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-03 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am, wrapup/Makefile.am: Remove build-variant support. | |||||
2004-10-15 | 2004-10-15 Gene Smith <gene.smith@seimens.com> | Joel Sherrill | 1 | -0/+5 | |
PR 691/bsps * startup/linkcmds: Correct bug in linker script. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-23 | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
2004-04-23 | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
2004-04-02 | * dlentry/dlentry.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 1 | -0/+4 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* startup/bspstart.c: Convert to using c99 fixed size types. | |||||
2004-02-19 | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect changes to bsp.am. | |||||
2004-02-06 | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* wrapup/Makefile.am: Convert to automake-building rules. | |||||
2004-01-30 | 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+8 | |
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use automake compilation rules. * dlentry/Makefile.am, startup/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above. | |||||
2004-01-30 | 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* wrapup/Makefile.am: Reflect changes to ../support/*exception_processing/*. | |||||
2004-01-29 | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto. | |||||
2004-01-05 | 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a. | |||||
2003-12-22 | 2003-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* dlentry/Makefile.am: Eliminate VPATH. * startup/Makefile.am: Eliminate VPATH. | |||||
2003-12-16 | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
PR 333/bsps * startup/linkcmds: Remove SEARCH_DIR. | |||||
2003-12-15 | 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* startup/linkcmds: Remove SEARCH_DIR. * startup/linkcmds.dl: Remove SEARCH_DIR. | |||||
2003-12-13 | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. |
