In your various bsp_specs files, even when ecrti.o is defined as a
startfile, ecrtn.o is not defined as an endfile. Instead it seems to
be in the library list - untidy.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
in the eth_comm BSP documentation.
based board.
