* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am,
console/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* canbus/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* canbus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* canbus/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* canbus/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* canbus/canbus.c, clock/p_clock.c, include/bsp.h, include/canbus.h,
include/coverhd.h, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, startup/bspstart.c, startup/mmutlbtab.c,
startup/setvec.c, vectors/vectors.h, vectors/vectors_init.c: URL for
license changed.
canbus/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained.
* canbus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* canbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/irq.c: Reflect changed to <rtems/score/cpu.h>.
* irq/irq_asm.S: Ditto.
* vectors/vectors.S: Ditto.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* irq/irq.c: Define loopCounter iff DISPATCH_HANDLER_STAT is set.
* startup/bspstart.c: include <bsp/irq.h>, <libcpu/cpuIdent.h>,
<rtems/bspIo.h>
* canbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(UARTS_IO_MODE),
RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* irq/Makefile.am: remove irq.h from EXTRA_DIST.
* wrapup/Makefile.am: Apply @exceptions@.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, irq/.cvsignore,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am,
vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New file.
* Switch the eth_comm BSP to use the "new exception processing model."
