for details.
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, console/rsPMCQ1.h, include/bsp.h,
startup/bspstart.c: Create bsp_get_work_area() into its own file and
use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
* Makefile.am, configure.ac, console/alloc360.c, console/console.c,
console/console.h, console/m68360.h, console/mc68360_scc.c,
console/ns16550cfg.c, console/rsPMCQ1.c, console/rsPMCQ1.h,
include/bsp.h, irq/irq_init.c, vme/VMEConfig.h: Initiate update and
testing. Add missing files. Does not run hello yet.
* console/debugio.c, console/polled_io.c, irq/openpic_xxx_irq.c: New files.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* acinclude.m4: Initial release of ep1a bsp
* ep1a/Makefile.am, ep1a/bsp_specs, ep1a/configure.ac,
ep1a/console/alloc360.c, ep1a/console/console.c,
ep1a/console/console.h, ep1a/console/init68360.c,
ep1a/console/m68360.h, ep1a/console/mc68360_scc.c,
ep1a/console/ns16550cfg.c, ep1a/console/ns16550cfg.h,
ep1a/console/rsPMCQ1.c, ep1a/console/rsPMCQ1.h, ep1a/include/bsp.h,
ep1a/irq/irq.c, ep1a/irq/irq_init.c, ep1a/pci/no_host_bridge.c,
ep1a/start/start.S, ep1a/startup/bspstart.c, ep1a/startup/linkcmds,
ep1a/vme/vmeconfig.c: New files.
