* acinclude.m4: Remove dmv177 and ppcn_60x.
* dmv177/.cvsignore, dmv177/ChangeLog, dmv177/Makefile.am,
dmv177/QUIRKS, dmv177/README, dmv177/README.net, dmv177/STATUS,
dmv177/bsp_specs, dmv177/cable.doc, dmv177/configure.ac,
dmv177/times, dmv177/clock/clock.c, dmv177/console/conscfg.c,
dmv177/console/debugio.c, dmv177/include/.cvsignore,
dmv177/include/bsp.h, dmv177/include/dmv170.h, dmv177/include/tm27.h,
dmv177/scv64/scv64.c, dmv177/sonic/dmvsonic.c, dmv177/start/start.S,
dmv177/startup/bspclean.c, dmv177/startup/bspstart.c,
dmv177/startup/genpvec.c, dmv177/startup/linkcmds,
dmv177/startup/setvec.c, dmv177/startup/vmeintr.c,
dmv177/timer/timer.c, dmv177/tod/todcfg.c, ppcn_60x/.cvsignore,
ppcn_60x/ChangeLog, ppcn_60x/Makefile.am, ppcn_60x/README,
ppcn_60x/STATUS, ppcn_60x/bsp_specs, ppcn_60x/configure.ac,
ppcn_60x/clock/clock.c, ppcn_60x/console/config.c,
ppcn_60x/console/console.c, ppcn_60x/console/console.h,
ppcn_60x/console/debugio.c, ppcn_60x/console/i8042.c,
ppcn_60x/console/i8042_p.h, ppcn_60x/console/i8042vga.c,
ppcn_60x/console/i8042vga.h, ppcn_60x/console/ns16550cfg.c,
ppcn_60x/console/ns16550cfg.h, ppcn_60x/console/vga.c,
ppcn_60x/console/vga_p.h, ppcn_60x/console/z85c30cfg.c,
ppcn_60x/console/z85c30cfg.h, ppcn_60x/include/.cvsignore,
ppcn_60x/include/bsp.h, ppcn_60x/include/extisrdrv.h,
ppcn_60x/include/nvram.h, ppcn_60x/include/pci.h,
ppcn_60x/include/tm27.h, ppcn_60x/network/amd79c970.c,
ppcn_60x/network/amd79c970.h, ppcn_60x/nvram/ds1385.h,
ppcn_60x/nvram/mk48t18.h, ppcn_60x/nvram/nvram.c,
ppcn_60x/nvram/prepnvr.h, ppcn_60x/nvram/stk11c68.h,
ppcn_60x/pci/pci.c, ppcn_60x/start/start.S,
ppcn_60x/startup/bspclean.c, ppcn_60x/startup/bspstart.c,
ppcn_60x/startup/bsptrap.S, ppcn_60x/startup/genpvec.c,
ppcn_60x/startup/linkcmds, ppcn_60x/startup/rtems-ctor.cc,
ppcn_60x/startup/setvec.c, ppcn_60x/startup/spurious.c,
ppcn_60x/startup/swap.c, ppcn_60x/timer/timer.c, ppcn_60x/tod/cmos.h,
ppcn_60x/tod/tod.c, ppcn_60x/universe/universe.c,
ppcn_60x/vectors/README, ppcn_60x/vectors/align_h.S,
ppcn_60x/vectors/vectors.S: Removed.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* startup/genpvec.c: Include <rtems/chain.h> instead of <chain.h>.
* startup/vmeintr.c: Include <rtems/vmeintr.h> instead of <vmeintr.h>.
* clock/clock.c, console/conscfg.c, console/debugio.c,
include/bsp.h, include/dmv170.h, scv64/scv64.c, sonic/dmvsonic.c,
startup/bspstart.c, startup/genpvec.c, startup/vmeintr.c,
timer/timer.c, tod/todcfg.c: Convert to using c99 fixed size types.
Reflect changes to bsp.am.
* clock/clock.c, console/debugio.c, include/dmv170.h,
startup/bspclean.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: URL for license changed.
* console/conscfg.c, include/bsp.h, scv64/scv64.c, startup/bspstart.c,
tod/todcfg.c: Removed incorrect statement about copyright assignment.
scv64/Makefile.am: Reflect having moved automake.
sonic/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/dmv177.cfg;
Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE,
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to
DMV177_USE_INSTRUCTION_CACHE.
* wrapup/Makefile.am: Apply @exceptions@.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
CONSOLE_USE_POLLED, HAS_RTC.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
converted to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
Used existing constants for bits on the register.
check for the presence of the DUART, SCC, and RTC. The SONIC check
needs to be added in the future as the network driver is libchip'ed.
to entire RTC with NVRAM included.
Deleted CSS interface related items.
Added items required to access DMA Control and Status Register so we
could figure out dynamically what the clock speed of the SCC really is.
to fill in the configuration table.
