path: root/c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (unfollow)
2005-04-282005-04-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-284/+0
* acinclude.m4: Remove dmv177 and ppcn_60x. * dmv177/.cvsignore, dmv177/ChangeLog, dmv177/Makefile.am, dmv177/QUIRKS, dmv177/README, dmv177/README.net, dmv177/STATUS, dmv177/bsp_specs, dmv177/cable.doc, dmv177/configure.ac, dmv177/times, dmv177/clock/clock.c, dmv177/console/conscfg.c, dmv177/console/debugio.c, dmv177/include/.cvsignore, dmv177/include/bsp.h, dmv177/include/dmv170.h, dmv177/include/tm27.h, dmv177/scv64/scv64.c, dmv177/sonic/dmvsonic.c, dmv177/start/start.S, dmv177/startup/bspclean.c, dmv177/startup/bspstart.c, dmv177/startup/genpvec.c, dmv177/startup/linkcmds, dmv177/startup/setvec.c, dmv177/startup/vmeintr.c, dmv177/timer/timer.c, dmv177/tod/todcfg.c, ppcn_60x/.cvsignore, ppcn_60x/ChangeLog, ppcn_60x/Makefile.am, ppcn_60x/README, ppcn_60x/STATUS, ppcn_60x/bsp_specs, ppcn_60x/configure.ac, ppcn_60x/clock/clock.c, ppcn_60x/console/config.c, ppcn_60x/console/console.c, ppcn_60x/console/console.h, ppcn_60x/console/debugio.c, ppcn_60x/console/i8042.c, ppcn_60x/console/i8042_p.h, ppcn_60x/console/i8042vga.c, ppcn_60x/console/i8042vga.h, ppcn_60x/console/ns16550cfg.c, ppcn_60x/console/ns16550cfg.h, ppcn_60x/console/vga.c, ppcn_60x/console/vga_p.h, ppcn_60x/console/z85c30cfg.c, ppcn_60x/console/z85c30cfg.h, ppcn_60x/include/.cvsignore, ppcn_60x/include/bsp.h, ppcn_60x/include/extisrdrv.h, ppcn_60x/include/nvram.h, ppcn_60x/include/pci.h, ppcn_60x/include/tm27.h, ppcn_60x/network/amd79c970.c, ppcn_60x/network/amd79c970.h, ppcn_60x/nvram/ds1385.h, ppcn_60x/nvram/mk48t18.h, ppcn_60x/nvram/nvram.c, ppcn_60x/nvram/prepnvr.h, ppcn_60x/nvram/stk11c68.h, ppcn_60x/pci/pci.c, ppcn_60x/start/start.S, ppcn_60x/startup/bspclean.c, ppcn_60x/startup/bspstart.c, ppcn_60x/startup/bsptrap.S, ppcn_60x/startup/genpvec.c, ppcn_60x/startup/linkcmds, ppcn_60x/startup/rtems-ctor.cc, ppcn_60x/startup/setvec.c, ppcn_60x/startup/spurious.c, ppcn_60x/startup/swap.c, ppcn_60x/timer/timer.c, ppcn_60x/tod/cmos.h, ppcn_60x/tod/tod.c, ppcn_60x/universe/universe.c, ppcn_60x/vectors/README, ppcn_60x/vectors/align_h.S, ppcn_60x/vectors/vectors.S: Removed.
2004-04-21Remove duplicate white lines.Ralf Corsepius1-4/+0
2004-04-21Remove stray white spaces.Ralf Corsepius1-12/+12
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-4/+4
* clock/clock.c, console/conscfg.c, console/debugio.c, include/bsp.h, include/dmv170.h, scv64/scv64.c, sonic/dmvsonic.c, startup/bspstart.c, startup/genpvec.c, startup/vmeintr.c, timer/timer.c, tod/todcfg.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/bspclean.c, startup/genpvec.c, startup/setvec.c, startup/vmeintr.c, timer/timer.c: URL for license changed.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+0
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c, startup/vmeintr.c: Fixed typo.
1998-08-06Card Resource Register was a 16-bit register not a 32-bit one.Joel Sherrill1-10/+0
Used existing constants for bits on the register.
1998-08-06Added support for the Card Resource Register. The new probe routinesJoel Sherrill1-0/+11
check for the presence of the DUART, SCC, and RTC. The SONIC check needs to be added in the future as the network driver is libchip'ed.
1998-07-30Added SONIC configuration information.Joel Sherrill1-0/+9
1998-07-30Changed comment to be more polite.Joel Sherrill1-1/+1
1998-07-29Simplified RTC base address.Joel Sherrill1-2/+1
1998-07-29Changed cast on RTC address and added base address of RTC fields as opposedJoel Sherrill1-1/+2
to entire RTC with NVRAM included.
1998-07-18Addresses for SCC were wrong. A and B ports were swapped.Joel Sherrill1-44/+25
Deleted CSS interface related items. Added items required to access DMA Control and Status Register so we could figure out dynamically what the clock speed of the SCC really is.
1998-07-15Added SCV64_Get_Interrupt_Enable().Joel Sherrill1-0/+1
1998-07-15Added CSCV64 functions and addresses.Joel Sherrill1-10/+56
1998-07-09Corrected z85c30 address and clock constants.Joel Sherrill1-4/+4
1998-07-05Added some address constants for the SCC and DUART to make it easierJoel Sherrill1-3/+10
to fill in the configuration table.
1998-06-13Added IRQ information.Joel Sherrill1-2/+31
1998-05-30Updated to current source and removed warnings.Joel Sherrill1-18/+19
1998-05-30New files -- from rtems-LM-980406 which was based on an RTEMS from 12/97.Joel Sherrill1-0/+215
This was called the dmv170 BSP in that source tree but since the DMV171 is now obsolete, we have transitioned to the DMV177 and have no intention of checking compatibility with any other models.
