* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Used existing constants for bits on the register.
check for the presence of the DUART, SCC, and RTC. The SONIC check
needs to be added in the future as the network driver is libchip'ed.
Tested all four ports. MC68681 as both polled and interrupt. Z8530 as
polled only.
This routines could be enhanced to determine if the SCC is present
since it appears from the DY-4 manual that a status registers indicates
this.
register access routines.
interrupt vector can be shared by multiple chips of varying types.
compilation section which used CONSOLE_USE_INTERRUPTS to switch all
ports between interrupt and polled mode.
to polled.
libchip/serial.
for the z85c30 found on the DMV177. This effort started with the
console driver from the Radstone PPC2. But some simplifications were
made in the hope that console.c can be made a shared file at some point
in the near future.
Split the debugio from console. This was done so at some point in the
future printk support as is found in the pc386 BSP can be shared
across all BSPs.
Changed #if defined to a #if check for CONSOLE_USE_INTERRUPTS.
This was called the dmv170 BSP in that source tree but since the DMV171
is now obsolete, we have transitioned to the DMV177 and have no intention
of checking compatibility with any other models.
