* acinclude.m4: Remove dmv177 and ppcn_60x.
* dmv177/.cvsignore, dmv177/ChangeLog, dmv177/Makefile.am,
dmv177/QUIRKS, dmv177/README, dmv177/README.net, dmv177/STATUS,
dmv177/bsp_specs, dmv177/cable.doc, dmv177/configure.ac,
dmv177/times, dmv177/clock/clock.c, dmv177/console/conscfg.c,
dmv177/console/debugio.c, dmv177/include/.cvsignore,
dmv177/include/bsp.h, dmv177/include/dmv170.h, dmv177/include/tm27.h,
dmv177/scv64/scv64.c, dmv177/sonic/dmvsonic.c, dmv177/start/start.S,
dmv177/startup/bspclean.c, dmv177/startup/bspstart.c,
dmv177/startup/genpvec.c, dmv177/startup/linkcmds,
dmv177/startup/setvec.c, dmv177/startup/vmeintr.c,
dmv177/timer/timer.c, dmv177/tod/todcfg.c, ppcn_60x/.cvsignore,
ppcn_60x/ChangeLog, ppcn_60x/Makefile.am, ppcn_60x/README,
ppcn_60x/STATUS, ppcn_60x/bsp_specs, ppcn_60x/configure.ac,
ppcn_60x/clock/clock.c, ppcn_60x/console/config.c,
ppcn_60x/console/console.c, ppcn_60x/console/console.h,
ppcn_60x/console/debugio.c, ppcn_60x/console/i8042.c,
ppcn_60x/console/i8042_p.h, ppcn_60x/console/i8042vga.c,
ppcn_60x/console/i8042vga.h, ppcn_60x/console/ns16550cfg.c,
ppcn_60x/console/ns16550cfg.h, ppcn_60x/console/vga.c,
ppcn_60x/console/vga_p.h, ppcn_60x/console/z85c30cfg.c,
ppcn_60x/console/z85c30cfg.h, ppcn_60x/include/.cvsignore,
ppcn_60x/include/bsp.h, ppcn_60x/include/extisrdrv.h,
ppcn_60x/include/nvram.h, ppcn_60x/include/pci.h,
ppcn_60x/include/tm27.h, ppcn_60x/network/amd79c970.c,
ppcn_60x/network/amd79c970.h, ppcn_60x/nvram/ds1385.h,
ppcn_60x/nvram/mk48t18.h, ppcn_60x/nvram/nvram.c,
ppcn_60x/nvram/prepnvr.h, ppcn_60x/nvram/stk11c68.h,
ppcn_60x/pci/pci.c, ppcn_60x/start/start.S,
ppcn_60x/startup/bspclean.c, ppcn_60x/startup/bspstart.c,
ppcn_60x/startup/bsptrap.S, ppcn_60x/startup/genpvec.c,
ppcn_60x/startup/linkcmds, ppcn_60x/startup/rtems-ctor.cc,
ppcn_60x/startup/setvec.c, ppcn_60x/startup/spurious.c,
ppcn_60x/startup/swap.c, ppcn_60x/timer/timer.c, ppcn_60x/tod/cmos.h,
ppcn_60x/tod/tod.c, ppcn_60x/universe/universe.c,
ppcn_60x/vectors/README, ppcn_60x/vectors/align_h.S,
ppcn_60x/vectors/vectors.S: Removed.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am: Remove.
* configure.ac, wrapup/Makefile.am: Reflect changes above.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* scv64/Makefile.am: Cosmetics.
* sonic/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
scv64/Makefile.am: Reflect having moved automake.
sonic/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/dmv177.cfg;
Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE,
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to
DMV177_USE_INSTRUCTION_CACHE.
* wrapup/Makefile.am: Apply @exceptions@.
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
that converts the hppa1.1 directory to automake.
NOTE:
* Due to not having a toolchain (gcc refuses to build) this patch is
untested.
* I omited/deactivated the pxfl subdirectory, because I don't
understand how it supposed to work.
Joel's note: It was right to ignore the pxfl directory. It should be
removed one the BSPs are moved outside the tree. This was an old hack.
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
