* acinclude.m4: New file.
* configure.in, motorola_powerpc/Makefile.am,
motorola_powerpc/configure.in: These modifications are in
support of switching the mpc8xx to the use the "new exception
processing model."
that contains:
* Removes MKLIB
handling)
converted to automake.
