2004-10-20 | Add MVME550 BSP | Eric Norum | 1 | -1/+2 | |
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Require automake > 1.9. | |||||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]). | |||||
2004-02-03 | 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -14/+1 | |
* configure.ac: Reflect having removed shared/*/Makefile.am | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -1/+0 | |
2003-02-20 | 2003-02-20 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 1 | -1/+2 | |
PR 349/bsps * configure.ac: Add glue to the powerpc/shared BSP to use the vmeUniverse VME-PCI bridge driver. | |||||
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-12-17 | 2002-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+2 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-12 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+40 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
