The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
sequence must be executed in MOTLoad before booting RTEMS to remove its network interface interrupt handlers, lest memory corruption occur
This define is no longer used.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
* Makefile.am, startup/bspstart.c: Formatting.
PR 1824/cpukit
* startup/bspclean.c, startup/bspstart.c: Return exit/shutdown status
back to boot_card(). boot_card() propagates this to bsp_cleanup() and
returns it to the assembly that started the application.
bsp_cleanup() prototype changed.
* make/custom/beatnik.cfg: Spacing.
* Makefile.am: Remove "SUBDIRS = .".
Remove "all-local:".
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* include/bsp.h: define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
* irq/discovery_pic.c, network/if_em/rtemscompat_defs.h,
* network/if_gfe/rtemscompat_defs.h, startup/bspstart.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* Makefile.am: Remove build_date.c.
* startup/bspstart.c: Remove BSP_build_date.
* network/porting/README, network/porting/if_xxx_rtems.c,
startup/bspstart.c: Remove CVS artefacts.
* Makefile.am: Remove -Wno-unused-variable.
PR 1682/bsps
* startup/bspstart.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/bsp.h: Do not include <bsp/bsp_bsdnet_attach.h> if networkign
disabled.
* network/support/bsp_attach.c: Include <unistd.h>.
* network/if_mve/mv643xx_eth.c: Fixed alignment attribute
in descriptor declaration. Not the pointers to the descriptors
have to be aligned but the descriptors themselves (didn't
cause problems but caused unnecessary holes in 'private' struct).
FIX: Added more robustness when number of available TX descriptors
drops to zero. (This can e.g., happen if the link goes bad causing
packets to stall in the FIFO.) At the following points the transmitter
is explicitly (re-)started:
o when link comes up and number of available TXDs is zero the
TX is restarted.
o on a failed attempt to send data due to lack of TXDs the
TX is restarted if swiping the TX ring doesn't yield any
buffers (i.e., if the # of available buffers is still zero
after the swipe).
