BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Update #3239.
Update #2833.
Update #2833.
Update #2833.
The device_t typedef is already provided by <sys/types.h> if _KERNEL is
defined.
Close #2874.
Update #2825.
Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes
in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>.
Clean up problems with htonl(). These functions are defined in
<arpa/inet.h>. This lead to some problems because they are defined in
<rtems/endian.h> too. Add NTOHL, ... to
<rtems/rtems_bsdnet_internal.h>.
warnings
Update #2408.
Update #2408.
The size of the sample executables without this option were:
221793 26856 14537 263186 40412 base_sp.exe
209281 25692 14497 249470 3ce7e hello.exe
202033 25072 11269 238374 3a326 minimum.exe
638049 94974 26821 759844 b9824 fileio.exe
243953 28604 14641 287198 461de nsecs.exe
254337 39408 15205 308950 4b6d6 paranoia.exe
224961 27024 14569 266554 4113a ticker.exe
224257 27792 18313 270362 4201a unlimited.exe
973889 215614 22173 1211676 127d1c cxx_iostream.exe
312369 45540 15209 373118 5b17e cdtest.exe
290177 37456 16361 343994 53fba capture.exe
The size of the sample executables with this option enabled were:
189633 22528 14517 226678 37576 base_sp.exe
175233 21388 14469 211090 33892 hello.exe
147265 19512 10949 177726 2b63e minimum.exe
595393 88650 26509 710552 ad798 fileio.exe
212561 24252 14621 251434 3d62a nsecs.exe
221953 35032 15181 272166 42726 paranoia.exe
193089 22696 14549 230334 383be ticker.exe
190561 23436 18285 232282 38b5a unlimited.exe
624149 52162 21361 697672 aa548 cxx_iostream.exe
280985 32516 15189 328690 503f2 cdtest.exe
256993 32928 16341 306262 4ac56 capture.exe
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
warning and clean up
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
sequence must be executed in MOTLoad before booting RTEMS to remove its network interface interrupt handlers, lest memory corruption occur
This define is no longer used.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
