* network/porting/README, network/porting/if_xxx_rtems.c,
startup/bspstart.c: Remove CVS artefacts.
* Makefile.am: Remove -Wno-unused-variable.
PR 1682/bsps
* startup/bspstart.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/bsp.h: Do not include <bsp/bsp_bsdnet_attach.h> if networkign
disabled.
* network/support/bsp_attach.c: Include <unistd.h>.
* network/if_mve/mv643xx_eth.c: Fixed alignment attribute
in descriptor declaration. Not the pointers to the descriptors
have to be aligned but the descriptors themselves (didn't
cause problems but caused unnecessary holes in 'private' struct).
FIX: Added more robustness when number of available TX descriptors
drops to zero. (This can e.g., happen if the link goes bad causing
packets to stall in the FIFO.) At the following points the transmitter
is explicitly (re-)started:
o when link comes up and number of available TXDs is zero the
TX is restarted.
o on a failed attempt to send data due to lack of TXDs the
TX is restarted if swiping the TX ring doesn't yield any
buffers (i.e., if the # of available buffers is still zero
after the swipe).
* include/bsp.h: BSP should not define
CONFIGURE_NUMBER_OF_TERMIOS_PORTS.
* network/if_em/Makefile, network/if_gfe/Makefile: Removed.
* Makefile.am, preinstall.am: Account for coverhd.h and tm27.h. Use
stubs for both.
