path: root/c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_pub.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-22/+0
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-1/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
