path: root/c/src/lib/libbsp/powerpc/Makefile.am (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* 2011-06-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-191-6/+4
| | | | * Makefile.am: Remove references to non-existing files.
* Whitespace removal.Ralf Corsepius2009-11-281-1/+1
* remove depratated powerpc exception APIThomas Doerfler2009-10-301-1/+1
* 2007-12-10 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-12-111-1/+2
| | | | | * Makefile.am, start/preload.S: moved preload.S to ../shared/start.
* 2007-12-10 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-12-111-0/+2
| | | | | | * shared/motorola/vpd.c, shared/motorola/vpd.h: added code (originally developed for 'beatnik') to read MotLoad VPD data from i2c eeprom.
* 2007-12-08 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-12-101-1/+1
| | | | | | * Makefile.am: merged shared/vme/vme_universe.c and shared/vme/vme_universe_dma.c into one file. Added support for Tsi148 driver (DMA).
* 2007-11-29 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-11-271-0/+4
| | | | | | | | | | | | | * Makefile.am, shared/flash, shared/flash/flash.c, shared/flash/flashPgm.h, shared/flash/flashPgmPvt.h, shared/flash/intelFlash.c, shared/flash/spansionFlash.c: Added flash programmer API, implementation and chip drivers for some intel + spansion flash chips (as found on mvme5500, mvme6100 and mvme3100 boards). A more appopriate place would probably be libchip but I don't know if the API is acceptable and if the implementation is generic enough (e.g., no CFI support) so I leave it here for now.
* 2007-11-21 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-11-211-1/+2
| | | | | | | | * Makefile.am, motorola_powerpc/Makefile.am, * shared/pci/detect_raven_bridge.c, Makefile.am, * shared/pci/generic_clear_hberrs.c: separated the generic version of _BSP_clear_hostbridge_errors() into its own file.
* 2007-01-29 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-01-311-1/+1
| | | | | | | | | | | | | | * shared/vme/VMEConfig.h: Added more comments about the semantics of the various symbols BSPs should define in this file. Removed declarations of BSP_VMEInit(), BSP_VMEIrqMgrInstall(). * shared/vme/vmeconfig.c: declare BSP_VMEInit(), BSP_VMEIrqMgrInstall() here. * Makefile.am, shared/vme/README, * shared/vme/vme_universe_dma.c (added): Added glue code implementing the VMEDMA.h API using the vmeUniverse driver.
* * Makefile.am,Till Straumann2007-01-191-1/+1
| | | | | | | | | | * ep1a/Makefile.am, ep1a/preinstall.am, * motorola_powerpc/Makefile.am, motorola_powerpc/preinstall.am, * score603e/Makefile.am, score603e/preinstall.am, * shared/vme/VME.h: moved VME.h from libbsp/powerpc/shared/vme to libbsp/shared/vmeUniverse; eventually, this (and other) VME API headers should migrate to cpukit.
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-041-0/+1
| | | | | | | | | | | * shared/vme/README, shared/vme/vme_universe.c: New files. * Makefile.am, motorola_powerpc/Makefile.am, mvme5500/vme/vmeconfig.c, shared/vme/VME.h, shared/vme/VMEConfig.h, shared/vme/vmeconfig.c: Several VME related upgrades and fixes, hopefully addressing PR#835: Separated API, API-implementation by a specific VME bridge driver and BSP-specific configuration of the driver into different files, describing their purpose in a README. All of these changes use the upgraded vmeUniverse.c driver.
* 2005-11-03 <strauman@slac.stanford.edu>Till Straumann2005-11-041-1/+2
| | | | | | | | | | * shared/irq/openpic_i8259_irq.c: New file. * ChangeLog, Makefile.am, motorola_powerpc/ChangeLog, motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259 specifica from generic irq handling into openpic_i8259_irq.c; added some compilation conditionals to help BSPs without ISA to omit ISA interrupts and calling i8259 code.
| | | | | | | | | | | * shared/startup/pretaskinghook.c, shared/startup/zerobss.c: New files. * Makefile.am, shared/startup/bspstart.c: Split pretaskinghook and zerobss into separate, reusable files; Fixed #PR837 (set exception in ram flag before initializing exceptions); Setup DBATs early, they are needed to access peripherals (Allows mvme2100 to use MMU); moved VME initialization into pretasking hook so that shared interrupts can be used for VME [shared IRQ facility needs functional workspace].
* 2005-11-03 straumanatslacdotstanforddoteduTill Straumann2005-11-031-1/+1
| | | | | | | | * Makefile.am, motorola_powerpc/Makefile.am, mvme5500/Makefile.am, mvme5500/start/preload.S, mvme5500/startup/bspstart.c, shared/startup/bspstart.c: moved linkcmds to shared area for other BSPs to use
* 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-171-1/+52
| | | | | | * Makefile.am: Merge-in shared/Makefile.am. * configure.ac: Remove shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog.
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-131-4/+5
| | | | | * Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(RTEMS_BSP_FAMILY).
* 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-091-3/+2
| | | | * Makefile.am: Misc cleanups and fixes.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-1/+1
| | | | * Makefile.am: Reflect having moved aclocal/.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-2/+2
| | | | Makefile.am: Reflect having moved automake.
* 2001-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-281-0/+4
| | | | * Makefile.am: Add DIST_SUBDIRS.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-1/+1
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-1/+1
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patch rtems-rc-20000104-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-101-0/+12
which converts the PowerPC BSPs to configuration and more automake. * Besides adding partial automake support, rsp converting all powerpc BSPs to make them compliant to the new configuration scheme, this patch attempts to fix several configuration bugs in powerpc related Makefiles.
