* shared/startup/bspstart.c: Comment out unused vars.
* shared/console/console.c: Remove stray local decl of "close".
* shared/startup/linkcmds.base: New file.
* shared/bootloader/exception.S, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/console/polled_io.c,
shared/startup/probeMemEnd.c: Update due to API changes.
* shared/start/start.S, shared/start/preload.S:
Make sure stack is 16-byte aligned and the TOS
is tagged with a NULL pointer (used as a terminator
when printing stack traces).
* shared/irq/openpic_i8259_irq.c: silenced compiler warnings.
* shared/motorola/motorola.c: removed
PCI_FIXUP_OPT_OVERRIDE_NAME for qemu - qemu gets it
right and this option messes things rather up.
PR 1799/bsps
* acinclude.m4: Update for qoriq BSPs.
* shared/include/linker-symbols.h: New file.
* shared/clock/clock.c: Fix to clear the first pending decrementer
exception.
PR 1837/bsps
* shared/motorola/motorola.c, shared/motorola/motorola.h: Add MVME2400
board with 750 CPU to list of supported Motorola boards.
* shared/bootloader/qemu_fakerom.S: Added work-around for
qemu bug 811683.
* shared/bootloader/head.S: disable USE_PPCBUG under qemu.
* shared/startup/bspstart.c: Select console *before* doing
any potential printk() (e.g., panic).
* shared/startup/ppc_idle.c: Need to enable HID0[NAP] on
a 7400/7455/7457 for MSR[POW] to have an effect.
* shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/bootloader/qemu_fakeres.c, shared/bootloader/qemu_fakerom.S,
shared/irq/irq.h, shared/motorola/motorola.c, shared/residual/residual.h,
shared/startup/bspstart.c,
Added 'qemuprep' BSP variant.
* shared/bootloader/misc.c: Copy residual data
_before_ decompressing the kernel since the firmware
may have stored it in an area that is overwritten
by decompress_kernel().
* shared/startup/ppc_idle.c: added an 'idle task' body
which switches the CPU into power-save mode. IIRC, this
cannot be used on real hardware due to errata :-( but
it still saves valuable host-CPU cycles when used by
the qemuprep BSP.
* shared/irq/init_irq.c, shared/irq/openpic_i8259_irq.c,
shared/pci/detect_raven_bridge.c: conditionally compile
ISA and PCI-interrupt related stuff only if BSP defines
BSP_ISA_IRQ_NUMBER > 0 and/or BSP_PCI_IRQ_NUMBER > 0,
respectively.
* Makefile.am: Remove references to non-existing files.
* shared/startup/sbrk.c: Remove extraneous '}'.
* shared/src/memcpy.c: New file.
* shared/src/bsp-start-zero.S: Use BSP_DATA_CACHE_ENABLED instead of
DATA_CACHE_ENABLE.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* shared/console/polled_io.c, shared/flash/spansionFlash.c,
shared/startup/bspidle.c, shared/startup/probeMemEnd.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/pci/detect_raven_bridge.c: Fix spelling.
* shared/start/start.S: Remove conflict lines in comments.
* shared/uboot_dump_bdinfo.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot-board-info.h: New file.
* shared/include/u-boot.h: Removed file.
* shared/include/start.h, shared/src/bsp-start-zero.S: New files.
PR 1689/bsps
* shared/flash/intelFlash.c: Scale erase timeout by actual
system clock rate rather than assuming a fixed value.
* shared/console/polled_io.c: Add BSP_poll_char.
* shared/startup/sbrk.c: Make bsp's sbrk a weak reference so that the
test of having sbrk() support in malloc can link.
PR 1606/cpukit
* shared/startup/panic.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
PR 1583/bsps
* shared/startup/panic.c: Remove reference to ITRON.
* shared/bootloader/em86.c, shared/bootloader/mm.c,
shared/console/polled_io.c, shared/irq/irq_init.c,
shared/startup/bspstart.c: Remove warnings.
* shared/flash/flash.c: Include <unistd.h>.
PR 1483/cpukit
* shared/pci/pci.c: Rename pci_config into rtems_pci_config_t.
* shared/irq/irq_init.c: Add missing initializer.
* shared/console/polled_io.c: Add prototype for boot_udelay.
* acinclude.m4, beatnik: Imported/added 'beatnik'
BSP.
* shared/start/start.S: Added AltiVec support (initializing
MSR[VE], VSCR and VRSAVE).
* shared/vme/vme_universe.c: moved extern declaration
out of local scope.
