* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* include/bsp.h, startup/Makefile.am, startup/bspclean.c:
Cleanup so the BSP works.
* acinclude.m4, configure.ac: Bender BSP renamed to OpenRisc
Reference Platform or ORP.
* configure.ac: Bender BSP renamed to OpenRisc Reference Platform
for ORP.
* include/bsp.h, start/start.S, startup/linkcmds: Patches which
were required to make the BSP run.
* acinclude.m4, configure.ac: Go back to name bender for
the or32/or1200 BSP.
* configure.ac: GO back to name bender for the or32/or1200 BSP.
* acinclude.m4, configure.ac: Update and fix minor things so this
BSP compiles and almost completely links.
* bsp_specs, configure.ac, startup/bspstart.c: Update and fix
minor things so this BSP compiles and almost completely links.
* startup/Makefile.am: New file.
* include/.cvsignore: Updated to account for more files.
* .cvsignore: New file.
* Makefile.am: New file.
* ChangeLog, acinclude.m4, configure.ac: New files added as part
of merge from OpenCores repository.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac, times,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/console.c,
console/console.h, include/.cvsignore, include/Makefile.am,
include/bsp.h, start/.cvsignore, start/Makefile.am, start/start.S,
startup/.cvsignore, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/main.c, startup/setvec.c, timer/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/timerisr.c,
wrapup/.cvsignore, wrapup/Makefile.am, ChangeLog: New files added
as part of merge from OpenCores repository.
