or1ksim BSP was initially named after or1ksim simulator, and it was
intented to only run there. But now it can also run on QEMU, jor1k and
real FPGA boards without modifications. It makes more sense to give
it a new generic name like generic_or1k.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
Implement new cache functions for or1k and create new bspstart function
for or1ksim to initialize instruction and data caches. Also, sim.cfg
is modified to enable/confiure cache units.
not updated.
This BSP is intended to run on or1ksim (the main OpenRISC emulator).
Fixed version according to Joel comments from the mailing list.
