* | libbsp/*/*/configure.ac: Remove references to bsp_specs in AC_CONFIG_SRCDIR | Joel Sherrill | 2017-11-27 | 1 | -1/+1 |
| | | | | Updates #3250. | ||||
* | bsps: Simplify RTEMS_BSP_CLEANUP_OPTIONS | Sebastian Huber | 2017-11-22 | 1 | -1/+1 |
| | | | | | | | | | Remove BSP-specific defaults for RTEMS_BSP_CLEANUP_OPTIONS to simplify the BSP configuration and documentation. Change defaults to: BSP_PRESS_KEY_FOR_RESET=0 BSP_RESET_BOARD_AT_EXIT=1 BSP_PRINT_EXCEPTION_CONTEXT=1 | ||||
* | Rename or1ksim BSP to generic_or1k | Hesham ALMatary | 2015-04-19 | 1 | -0/+30 |
or1ksim BSP was initially named after or1ksim simulator, and it was intented to only run there. But now it can also run on QEMU, jor1k and real FPGA boards without modifications. It makes more sense to give it a new generic name like generic_or1k. |
