* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* startup/Makefile.am: Ditto.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c:
URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* configure.in: Remove.
* acinclude.m4: New file.
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
