2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-03-17 | Remove eof include file | Ralf Corsepius | 1 | -1/+0 | |
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+2 | |
2006-01-12 | Remove all-local:. | Ralf Corsepius | 1 | -2/+0 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Cleanup. | Ralf Corsepius | 1 | -1/+0 | |
2006-01-11 | New. | Ralf Corsepius | 1 | -0/+47 | |
2006-01-11 | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -41/+6 | |
* Makefile.am: Add preinstall.am. | |||||
2005-05-26 | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* include/bsp.h: New header guard. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -5/+9 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-03 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -67/+17 | |
* Makefile.am: Remove build-variant support. | |||||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-23 | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -6/+15 | |
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
2004-04-23 | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -14/+39 | |
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -10/+5 | |
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
2004-04-21 | Remove duplicate white lines. | Ralf Corsepius | 3 | -5/+0 | |
2004-04-21 | Remove stray white spaces. | Ralf Corsepius | 4 | -19/+19 | |
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 3 | -3/+0 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+7 | |
* include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 7 | -15/+21 | |
* clock/ckinit.c, shmsupp/getcfg.c, shmsupp/lock.c, startup/bspstart.c, timer/timer.c, timer/timerisr.c: Convert to using c99 fixed size types. | |||||
2004-03-09 | Remove refs to Makefile*. | Ralf Corsepius | 1 | -2/+0 | |
2004-02-19 | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -4/+35 | |
* Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Reflect changes to bsp.am. | |||||
2004-02-03 | 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -4/+5 | |
* configure.ac: Remove AM_CONDITIONAL(HAS_MP). Remove RTEMS_CHECK_MULTIPROCESSING. | |||||
2004-02-02 | 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 15 | -212/+117 | |
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2004-01-29 | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+7 | |
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+7 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -0/+13 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto. | |||||
2004-01-05 | 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -4/+7 | |
* wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a. | |||||
2003-12-18 | 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -12/+5 | |
* wrapup/Makefile.am: Remove GENERIC_FILES. | |||||
2003-12-13 | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -6/+10 | |
* startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+8 | |
* startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-09 | 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -11/+13 | |
* startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes. | |||||
2003-12-03 | 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 8 | -9/+15 | |
* Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * shmsupp/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics. | |||||
2003-12-02 | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 7 | -6/+15 | |
* clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * shmsupp/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH). | |||||
2003-09-29 | 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -28/+18 | |
* Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 15 | -14/+22 | |
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c, startup/linkcmds, startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c: URL for license changed. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -8/+8 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 9 | -21/+32 | |
Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. shmsupp/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | |||||
2003-08-14 | Correcting to include PR numbers. | Joel Sherrill | 1 | -0/+1 | |
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-08-06 | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -3/+5 | |
* bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused). | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 2 | -1/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). |
