* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
that converts the no_cpu directory to automake.
