* | no_cpu: replace no_cpu_isr with rtems_isr | Gedare Bloom | 2012-04-16 | 1 | -2/+2 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
| | | | | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c, startup/linkcmds, startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+44 |
