do
echo $b
# echo $g
-i $b
done
Conflicts:
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove unnecessary include of bsp.h
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* include/bsp.h: New header guard.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
Reflect changes to bsp.am.
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c:
URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
converted to automake.
that converts the no_cpu directory to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
