* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, startup/bspstart.c: Create
bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* startup/main.c: Removed.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
Remove RTEMS_CHECK_MULTIPROCESSING.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
Reflect changes to bsp.am.
* configure.in: Remove.
