* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
